Extended my axle dump exhaust out the bumper
Mackhedq
minnesota
If youre gonna be dumb you gotta be tough
Got tired of the drone on my axle dump exhaust. Even after adding a resonator it just was annoying around cruising speeds. Tube use is 2.25". Wish I had more 2.5" but this was free so I can't cry too much
Having the outlet of the exhaust exit between the road and the body can be very annoying. Just bringing it out to the side should make a big difference for you.
Looks like a tight squeeze where pipe goes over the frame. Don't let it touch the underside of the body, could start a fire in the carpet. Also.....that outlet on the left wall of your work area looks suspicious.
that is the craziest exhaust run i have ever seen. y'all ran that pipe through every tiny spot it would reach. i would go out the side too. under the vehicle drove me crazy too
