RobinHood
So l purchased the brake lines outlined for extending my front hoses found in the tech library...
http://www.therangerstation.com/tech_library/ReplacementBrakeLine_Front.html
It appears the passenger side will work with no problem. It looks simple enough... as for the drivers side there is a junction block with two lines in it. l cannot figure out how the new lines tie into this block or where they attach to extend the lines out. Do these part numbers work for all rangers or just 1st generation? The truck is a 94 4x4 4.0
l know this is a brake question, but it pertains to a lift and this forum is frequented more often... thanks for the help
