extended brake hoses
BackWoodsDrifter
can anyone tell me where i can ,some extended brake hoses i just recently installed my 4inch rough country lift
Rough Country, Pro Comp, James Duff, Skyjacker, probably Summit. Look around, you will find them.
I got mine from Goodwrich. You can get them in any length imaginable pretty much. My first set were 24". Mine came with female ends on both ends (which just attached directly to the solid lines) and I just bought the fittings i needed, like a banjo block.
Its just a matter of finding a parts store that carries that brand of brake lines. Although I'm sure you could find someone online that sells them.
just an update on my search for lines... the fittings are not interchangeable between 98+ and earlier models as i had hoped so it looks like i will have to get some lines custom made in the length i need
