Explorer to Ranger tire swap
raascal
Will I have any problems swapping stock 02 Explorer EB 16 in rims over to a 02 Ranger XLT 4.0 4x4
The lug nuts might be tight?
The bolt circle is the same, it's worth measuring and comparing the back spacing before you buy them.
Backspace is different. Wheels will be more sucked in.
Also check the lug nuts. May be hub centric and not use conical lug nuts it’s like a Ranger.
Will look a little goofy and the tires might rub a little but they will “work”
2 door/Sports are the same as a Ranger all the way around for fit though.
