explorer rear ?
twoll86
U.S. Military - Active
caseyville,il
for those of you who have put a explorer rear in your lowered ranger what did you do for shock mounts?
edit i read on RPS that you could use 2 passenger side explorer mounts is this true any one tried?
The mounts can be used on either side, if you have the saddle tank, then you will need to mount the to the rear, and make a crossmember for the shocks to attach to.
I personally run a fuel cell, so I mounted mine to the front, but am goin to change them to the rear for more room around the exhaust, as I have 3" exhaust.
