LivinOnTheEDGE
Hi all, I've recently mounted the explorer ohc, but the display will not turn on, Ive check all my connections and I'm sure there fine, the map lights will turn on but nothing else, the main power wire I'm using has 11.85 volts but when i connect it to the harness, nothing happens, and I've made sure the wires were connected with the harness with the proper colours, and when i bought the console i tested it in an explorer and it worked so I'm completely lost, any help would be appreciated, thanks
-Mike
-Mike
