rickrmf
- Mar 1, 2010
- Automatic
Hi,
I put a 98 Explorer gauge cluster in my 96 Mazda B4000. I have just one problem left to solve. The coolant temp gauge goes all the way up to redline, but I know the truck is not overheating. All the other gauges, and warning lights work fine. I checked in to this and have been told the sender for the Explorer has a two wire connection, as opposed to one one the Mazda or Ranger. If I get the connector and sender from the Explorer, how should I wire it? That is which of the two wires should I connect to the truck wiring? The other possable cause could be, when I was cleaning the cluster out before I installed it, I bumped the needles around a little. Could it be that I need to reset the position of the needle? Any help on this would be appreciated!
Thanks, Rick
Thanks, Rick
