explorer a4ld fluid burp
pzilla
swapped in a good recently rebuild a4ld in my 94 exp. came out of a 1993 3.0L ranger. i swapped over the pump and bellhousing.i did not change main seal or alighn pump. recently i was towing a sled trailer with few bikes on it in high elevation and the main seal seemed to push out less than a quart of fluid. so i had it towed home. still drives and works but fluid smells bad and i read that i shuld have put in new seal and alighned the pump. i also have 33" tires... any suggestions? i also dont have the best radiator or tranny cooler. other than the fluid burp, i put 600miles on it with no trouble. thanks for any help
