No, it won't. The rotor, caliper and caliper mount will hold the axle and tire onto the housing. And I wouldn't be worrying about 'weak' c clips on a 31 spline 8.8 anyway......
If you are that worried about it Superior Gear and Axle sells a kit called the Super 88, has c clip eliminators.
I also know moser sells them for the 28 splines, not sure about the 31's
c-clip eliminators have nothing to do with the brakes. The replace the weak c-clips that hold the axle shaft in the housing.
doenst matter which style brakes you have, if the c-clip brakes, then your axle can and will come out of the housing.
