bdavis
- May 29, 2008
I have a '93 2WD Supercab with the 4.0. Looking to swap in an Explorer 8.8 rear. My truck has rear wheel ABS. If I swap in a disk-braked Explorer rear, will I need to swap to a disk brake master cylinder? If so, how big of a pain is this. Also some places on here I have read that the Explorer rear is 1.5" wider, other places it says 3" wider. Which is it? My plan is to add a 3" body lift and run 31x10.50s w/ 4.10 gears. Will the wider rear cause the tires to stick out from the rear a whole lot? Just trying to get all the info I can before I dive in.
