AgPete139
09/2014 OTOTM Winner
OTOTM Winner
Solid Axle Swap
TRS Banner 2012-2015
- Aug 12, 2007
- Houston, TX
- 4.0 V6
- Total Lift
- ~9"
- Tire Size
- 35"x12.50"x17"
Hm.
Also...
So, I just thought about these:
We'll try and get you straightened out.
Pete
- You could get a volmeter and make sure your TPS is at ~.90 - .99? (What you do is get 2 small pins, stick them in the TPS wires, and measure them with your multimeter device. Idle should be around .90 - .99 volts while WOT is going to be well over 4.00 volts.)
Also...
- Did you pull the automotive trouble codes yet?
- Could it even be oxygen sensors?
- Is it getting really cold where you are, and the motor is compensating?
- If you are absolutely sure there are no gasket leaks, and your vacuum lines are all hooked up, have you considered fuel?
Pete
