exploder add a leaf question
PaleBlue90
Solid Axle Swap
RBV's on Boost
Aurora Colorado
i got 2 inch add a leafs for the rear of the exploder, how do i go about adding those leafs exactly? ive never done a add a leaf and would like any suggestions,etc. do i just pull the leaf pack apart add the leafs then put the pack back together?:icon_welder:
Yep. Put a c-clamp on the pack and take out the centering pin. Put the add a leaf in, making sure to put the longer leafs on top and shorter leafs (if any) on the bottom. Then clamp it back together and put the pin back in.
thanks a bunch Sunk, i figured thats what it was gonna take. i think the hardest part is going to be those rusty bolts....should i replace them?
Yeah you can... it may be easier to just torch or grind them off.
thats what i was figureing, would you happen to know the length on those bolts? i kno the grade just not the length
Can't remember off hand.... If you bought an AAL kit, it should have bolts. If not, just measure what you need.
thanks a bunch, ill take a look in the morning. i really am hopeing i can get it finished tomorrow:D
