explane this
greenbeen89
I hot in my 95 5speed took off from my bros and got to the end of the road which is about 1mi went to pull out up a hill and the clutch acted slow to release if u dump it does fine punch it does fine help me with this 1 I've had my clutch slip and just go out but not this
If I've translated your post to English well enough, it sounds like if you release the clutch slowly it works just fine but if you let up off the pedal quickly the clutch engages slowly?
I had this happen in my B2, I attributed this to the bellhousing coming loose from the tranny, but your truck doesn't have a removable bellhousing.
what i got out of it is if he dumps the clutch, it engages, and its not slipping like a worn clutch, like if you mash the gas, his problem, i think, is if he lets up normally on the clutch, its slow to engage?????
Yea sorry sounded good in my head my phone did the I hot thing lol. If I let out normally it slips on that hill for sure it really isn't an big hill I got the truck 2-3 months ago and they said it was a new clutch but im sure everyone knows how that is. The rest of the way home I tryed to get it to do it again and couldn't get it to do it I dumped the clutch all that did was spin tires and punched it at 10 mph and was fine im thinking im going to have to put a new clutch in but though I would c what y'all said
hopefully its just air in the line, before you replace a clutch, i'd try to bleed it at the slave cylinder, if you look at the tech library, there's an article on how-to, but if its not acting up, i'd leave it alone no use to fix something that's not broke.
Dude, stay in school.
Wonder if there's a slight glazing beginning to occur to the clutch disc, pressure plate, or the flywheel? Not enough to cause full-time slippage when "dumped", but when gradually engaged it slips. Just a thought.
