- Feb 22, 2011
- Mississippi
- 3.0 V6
- Total Lift
- N/A
- Total Drop
- N/A
Would it be advantageous to upgrade to a 3” exhaust with the stock manifolds?
No, a 3.0 is best at 2 1/4" to 2 1/2" piping. My 94 3.0 5spd has 2 1/2" piping on it along with the Flowmaster original 40. That setup has been on my Ranger for 18 years. Sounds good, now with a rebuilt engine it sounds even better.
Unless you have a +5L engine, or a diesel, nothing benefits from 3 inch pipes.
Which Flow master did you go with?
If I took out the Cat would it cause a code to pop up?
An 88 has no way to see if the cats are there/working, but it is against forum rules to discuss their removal and a Federal felony to remove them. They also don't present nearly the issues they did back in the 70s when they were first introduced. A cat is not a restriction to proper flow unless it is coming apart. A gutted shell will have the same power robbing effect as stupid huge pipes do because that's what it becomes.
Sorry I didn’t specify the year it is a 94 Mazda B3000. I haven’t changed the tag under my name.
Then change "88" to "94" and leave the rest of my original response the same.
Sounds good thanks for the info. I have always been told to get rid of the cat to gain HP but I know you are a mechanic and I will not be doing that. Mostly rednecks telling me to take out the cat.
