Dweano
Hey guys. Well...I am pretty sure my truck has an exhaust leak. The exhaust sounds "different" coming from under the hood. I am pretty sure it is located between where my pacesetter header meets up with the downpipe part of the y-pipe...if anyone with headers know what I am trying to say. Its the connection that is around the drivers side framerail. I can try to take a pic. Now I know...pacesetter sucks, headers leak...la la. But I can't put my stock manifolds on now and a bonus is that this leak is not between to header and the header, just between the header and the downpipe.
I also remember that these were weird...they weren't straight flange to flange, they were a kind of ball and socket design...with part of the "ball" part cut out for the exhaust to pass thro. Then it fit into the socket part slightly. I am thinking for a solution I could maybe undo the y pipe (no easy task, those connecting bolts are probably rusted) and get a 3 hole gasket and slip it in between the ball and socket part. It wouldn't be straight, but if I tighten it it should in theory make a seal between the ball and socket part?
That is just my proposed solution...if anyone else has had this problems and fixed it I would much appreciate some help!
Also...how bad are exhaust leaks? Do they kill power and MPG's? Or just sound weird?
