EVTM Help
96JackedMazda
I have not been able to find any EVTM manuals in PDF online.
The issue I have,
Currently in a major build, 1996 Mazda b2300 2wd.
I have swapped out my 1996 OBD2 2.3L for a 1992 Ford EX. 4.0L manual transmission and manual transfer case.
Just finished a SAS with DANA 30 High pinion leaf spring.
I need someone that has EVTM for a 1992 4.0L wiring and also 1997 4.0L wiring.
I need to figure out the wiring to convert the 1997 harness 104 pin computer over the 1992 60 pin computer and get it running. I do not need any of the OBD2 stuff because I am Running obd1 now.
I have everything in the truck, including the 1992 Computer. All the wiring is plugged in up the harness connector from computer to main connection.
So if any one had copies of the wiring i could use that would be great really like to hear this thing.
Thank you
Justin
Will be doing a full Post including pictures and video once running.
:icon_welder:
