2.3L ('02-'11) Esslinger Duratec to SBF Bellhousing Adapter
D30... gross... those are just about a giveaway item if you can find a Jeep guy who is upgrading. I wouldn't pay much for one and they're almost not worth the time it takes to install it. Once you add the cost of a gear change it's REALLY not a good deal. The only nice thing about them from our perspective is the bolt pattern. I would really hold out for a D44 from a JK and a matching rear... or a Rubicon TJ D44... or a half ton Ford D44... or I believe some Dodge applications had driver drop D44 axles too. Money spent on a D30 is money wasted.
The trans gear swap deal isn't difficult. May be difficult to convince many shops to take on that project. I have done it several times, the main issue is when you tear yours apart and find worn out parts... you really have to watch for that, it has bit me in the ass.
That 3.0 and t-case is not ideal. You'll have the output shaft you need but the t-case is useless unless you rig up a harness to shift it electronically and it won't have the shifter attachment for a manual t-case on the tailhousing. Moot point if you planned on running an Atlas or something someday but I would really hold out for a 97 or older trans and a 1354 manual shift t-case.
My original plan's if the 2.3L couldn't be used was to swap in a 302 v8. But since the 2.3L could be used, I figured it wouldn't be pushing much power to the point of damaging a D30, so why install something more expensive & heavier.
I'm almost tempted to pass on the 2.3L and start working towards a v8 swap. It would involve a body lift to help with header issues & possible bellhousing clearance, but the parts seem easier to come by. I'd definitely upgrade to a D44 front and 8.8 rear if I had more power to run them. A pair of the new Gladiator axles sound cool, but prices are running $4k + for a pair. Although I'd really like to keep it at a factory width axle.
Personally I think you have one of the most reliable, long lasting engines used in the Ranger platform... sure it doesn't make a ton of power but IMO simplicity of repairs trumps power every day in an offroad rig. That said for the same price as a junk D30 you can get an old Ford D44 that is only marginally heavier and has bigger everything...and you can put chromoly shafts or RCVs in it and be totally bulletproof. I think that and an Explorer 8.8 are a stupid strong combo for a 4 cylinder.
I am just sayin' as someone who has V8 and solid axle swapped a Ranger and wheeled it a lot :icon_thumby:
4k for a pair of axles with the right gears, fresh brakes, potential lockers, etc could be a steal. Especially if you skip over building something several times and get what you want right off the bat. Some of the buggy guys I wheel with have 10k+ into ONE axle... I have about 2500 into my D44, it adds up.
I did see a set of 2021 Rubicon axles for sale with electronic lockers, 4.10 gears, drive shafts, draglink, & tirerods, complete but minus the rear brakes listed on facebook for $4,600 by a local shop.
Pretty hefty investment, & I'm pretty sure it's a bit inflated due to the pandemic/inflation rates.
So you just bought a Toyota?
After searching around for specific parts to change out my 2wd to 4wd, I came to the realization that finding the parts was going to be a real issue to build what I wanted. Pretty sure that most Rangers these days are picked clean or were crushed & sold as scrap.
So I ended up deciding that I'd be better off in the long haul to just buy a factory made 4wd. With all the parts I'd have to collect and store away, I didn't want the Mazda to become a project that took years to complete. The truck would have been really cool & the way Ford should have built them, but not an easy task to accomplish second hand in 2021. Maybe if I swapped out the entire drivetrain, but after that a whole other truck can be bought and driven. I'm still keeping the Mazda, but it'll probably get a standard v8 swap later on when the 2.3L gives out.
So this really happened......
I am.
But your original plan was perfect. So a sad deal to see.
If I come across the parts, it's possible to still go through with it, but it's going to take a long while before I can piece it together.
@Tikker: One last question for you - does your B2300 have torsion bars or coil spring for front axle?
Oh yea I forgot about that, 2wd torsion bar and 4x4 frames are basically the same. The coil spring 2wd frames are way different than 4x4's. I don't think there is anything you can do with a 2wd coil spring frame since the frame is built around the coils fitting up inside it. :dunno:
Well....you put a leaf or coil solid axle in it...
Or a ttb.....or a bad ass long a arm ifs....
Or skis.. coilovers trailing....
Anything you want.
Only the 2wd Edge models had torsion bars, the rest are coil springs and completely different. The Edge's you could just get some junkyard parts and make a 4x4 out of it roughly like a 4x2 Bronco II...
