Escorts 2nd SAS
I'd you need the drill bit or the reemer, I have both. I finished my 1 ton TRE on the D44 a couple months ago.
You can get a 7/8" and a 1" drill bit at rural king (ruralking.com if you dont have one local) and use the tie rod taper adapter that slides into that size hole. Ive seen both sizes, and have mine setup to use that type...
SVT
Or just run a rod end and use a straight hole.
Sent from XT907 using Crapatalk
Ran 3/4" Ruff Stuff rod ends for over 35K with no issue. Less than $50 to replace all 4 once a year.
Wow, it's been a long time since I updated this. Not much has happened, it is no longer my DD so most of the time it sits in the garage. It has the same tank of gas in there for the last 4 months.
But this year I plan on doing a bunch of wheeling, try to at least once a month all this year.
Sent from my SM-N910T using Tapatalk
Ben, you might want to start running stabyl fuel stabilizer in your tank since it sits for any length of time. Trying to move within the next few months up to around henderson/evansville area...
SVT
Oh I put some in the tank. All is good.
Cool, a little closer my way.
Yep, gonna have to hit some trails together this year, when I get one of my rigs going...
SVT
Hopefully I have something this year too. :icon_thumby:
That makes two of us....well three if we count the B2. We all decided to sell or rebuild this fall.lol
Since life has settled down a little for me, I am going to make some changes to the ranger in the next few weeks. I have a trip planned at the end of March and need to get a few things changed.
Things on the list, b2 fuel tank, rear bumper, spare tire mount, steering change, hydro assist installed, saginaw pump installed,and possibly thinking of an ARB for the D30
