Escorts 2nd SAS
Question is, when can i be able to afford the shipping. Winter time if when my job gets slow so it may be awhile before i can get it.
Sent from my SPH-D710 using Tapatalk 2
I figured, that's why I've taken my time boxing it. It's not going anywhere, just let me know when u want it.
Sent from my HTC VLE_U using Tapatalk 2
stuff it in a flat rate box!:icon_bounceblue:
Don't think they make one that big.
look into shipping it Greyhound... some places they are super cheap to ship to, others they cost just as much as Fed-Ups
Ordered another set of 1ton tre inserts from ruffstuff along with 7/8x3/4 rod ends and adapters. I have 13 days off for Christmas shutdown so I will use that time to redo the steering. Going to try it with over the knuckle and see if it helps. If the tre won't work right, ill just redo it all and use the rod ends. I still have enough dom left over to make a new tierod if needed.
I have two weeks off work for Christmas too, not that i really want that much time off.
Are you planning on slipping a assist cylinder in this time?
Mine should be in the mail as we speak. Crossing my fingers that my pump can handle hydroboost and hydro assist steering.
-PlumCrazy
-PlumCrazy
That would be my plans eventually.
I plan on pulling the axle out to make welding brackets easier. Plus I have to modify the sway bar tabs to make room for the draglink.
So if that ram will fit, great. But if not, ill just have to buy a different one.
Looks like an exo cage will in the planning stage now.
Thats going to be badass
Yes it will.
I have a plan in my head, just hope it will turn out right.
Any one have ideas? I'm open for suggestions.
I would build some sliders out of 2x4 box, then bring your exo up rights off of those. I really like how Kyle M and 97TrailRig ran the tube through the fender then up the a pillar. I want to do something similar, but my snorkel in the way.
-PlumCrazy
Stop making my todo list bigger....
-PlumCrazy
That is the plan, maybe. It has to be functional but simple. Also want to keep the weight down. Basically if it rolls over a few times, I want to be able.to flip it over and drive home.
