Engine/trans Removal possible? '99 2wd 2.5/5spd
300KRANGER
It looks like it may be more trouble than it is worth to try and remove the engine and trans together. Anyone do it? I am swapping a 2.5 with only 68K and 140-155compression for my 302K 2.5 with 90-115compression. On the 90lb cylinder it read 0lbs one time and 90lbs the next, so should I really only consider it as 45lbs??!!! LOL
Thanks,
300KRANGER
is the truck 2wd or 4wd, that will determine alot in being able to pull it as one piece
shouldnt be too bad pullint it out in one piece, just make sure to take off the fan and that will give u all the extra room u need, just gotta pull it out front end up to get the right angle
