- Feb 22, 2011
- Mississippi
- 3.0 V6
- Total Lift
- N/A
- Total Drop
- N/A
First I want you to know that in no way shape or form a mechanic. I am a do it your-selfer. Personally I of think of myself as a jack of all trades and master of none. This is just for your information (FYI). This is my personal experience. So with that aside let me begin.
I wanted to take a minute and give you info on my past year and a half experience with my engine rebuild. My engine crapped out on me, it had low compression, which I believe the rings were shot. So I needed a new engine. I had a friend who worked at Orielly's auto and he told me about the rebuilt engines they sold. The engine had a 3 year unlimited mileage warranty on a long block. I said heck yeah. So I got sent in the old and two weeks later we installed it. I was excited and ready to get on the road little did I know that the engine I bought would soon turn into a year and a half nightmare. To shorten this story the engine came from a company called "Power Torque". Well the engine ate about 12 distributor gears. I had two mechanics look at it and talked to several others and no one knew what the heck was up. It was either the oil pump or it was binding some where. I tried shimming the oil pump ect..... At the end of the day I was left with a truck that was not running and $2,400 down the drain (the engine was only $1,500). The company I bought it from would not help me In any way. They wanted me to fork out the money to bring it to a mechanic and they would reimburse me. I was out of money. Some of this is my fault I did not read the warranty details fully. So I finally saved the money and had it rebuilt locally and ever since it has been running fine. They told me the auxiliary shaft hole was too small and they had to bore it out.
The point to this was to let you know if you have the money to get your engine rebuilt I would strongly consider doing it locally by a well known engine rebuilder because they will fix it if any thing is wrong with it, as far as the internal engine goes. The warranty is only good for a year but there is a lot less headache involved. Dealing with a engine rebuild company in another state is a hassle.
Please consider this before going and getting an engine from any of the auto parts store in your area.
Thanks for reading and I hope this saves you the headache I went through.
