redstx40
Looks like its time to replace the motor mounts as well as the tranny mount. I read the all data on the replacement procedure for the engine. It just says to remove the nuts/bolts on the mounts and then jack up the engine by placing a jack under the oil pan (using wood inbetween).
Is it this simple or is there more to it? Any tips?
Also for the transmission mount, do I just take off the nuts/bolts and raise the transmission as well?
Any help would be appreciated. Just need to make sure that I can raise the engine from the oil pan without damaging any wires/hoses or the oil pan itself.
Theres not much info on the process of removing the tranny or engine mounts on forums.
Thanks
92 Ford Ranger STX 4WD V6 4.0L Auto with almost 250k!
Thanks
