blackcloud
- Apr 10, 2011
I just got my 1994 4.0l ohv 2wd 5spd yesterday. I have plans for building it into a prerunner and would like to keep the 4.0.
I just got it running this morning on 6 cylinders cause the coil pack didnt have spark on cyl 2. From a cold start it runs fine and sounds good after about 1 min of running a faint knocking starts. When revved the knocking sounds a lot louder between 2000-3000rpm and goes away at idle. it will also go away with stedy acceleration on the highway but that is under load. if there is no load on the engine (in neutral) it will knock with any kind of increase in engine speed. It sounds like it could be a lifter cause a rod would sound worse when cold right?
Any help would be great i have read many posts about similar sounds but none with the same symptoms as mine any help would be greatly appreciated.
