MaineRanger
- Sep 15, 2009
- Automatic
Ok so I have two issues , they may be related or not at all. About this time lastyear I was getting a strange noise from under the hood, it sounded like a shop vac that had a piece of paper Stuck in the tube mixed with a fog horn, it only happens when its cold out at lower speeda and rpms, you have to rev it up a little to get it to go away, some times it happens w/ the ac on sometimes w/o, it always happens in slow moving stop and go traffic. I have tried tp get out and listen but never been successful because it stops when you are parked for more then ten secs. Any ideas ?
my other issue is an engine code of too lean, some times on bank one some times on both, this started happening ahout two weeks ago. Checked for vaccum leaks amd got nothing, I am thinking mabye a bad fuel filter or other fuel line items scince this started after filling up with some old gas and fixing a rotted out fuel filler neck. What do you guys think, am i right to think that if its not a vaccum leak?
