AllBlackBimmer
So this morning it was very cold and snowing... I don't think that is the cause of my issue, but am just noting it.
I get on the highway and am driving slow due to the conditions... about 30-40mph in 2wd.
At this point, I have already been on the road for 10-15 mins and my engine was at normal operating temperature.
Not under heavy load, just cruising along, the truck seemed to sputter and hesitate for just second... it did this 5-10 times on my 10 mile highway drive.
Under heavy load - I.e. pushing the gas pedal threw the floor, there is no issue. At idle and during cold startup, no issue. When accelerating and coasting without pushing the gas pedal no issue.
Only when cruising along at highway speeds did I notice this.
I don't think its a transmission thing...
Engine is 4.0 SOHC.
I know I should probably check the MAF sensor and fuel filter form searching the forums, but does anything have any insight as to what it might be?
Most of the other "hesitation" threads I've seen seem to be under heavy load, or going uphill or towing, or had issues during idle or startup... I didn't experience any of those issues.
I was on pretty much flat ground, cruising, lightly touching the gas pedal.
I will be making an appointment to take it to the garage this afternoon... I just bought this truck and it has a 3 month warranty on it.
Engine is 4.0 SOHC.
