TremblantRanger
- Mar 23, 2012
I was replacing my throttle body gasket this weekend, and I noticed that the main engine wiring harness was resting against the EGR tube, and was partly melted!!! It's the one going to the ECU in the upper passenger side firewall going to some kind of junction block behing the power steering pump, see picture. Pictures are for visualization purposes; not from my truck. My question is: up to that lunction, it seems one piece exept for 3 smaller harnesses going from it. Crank sensor, cam sensor, and couldn't trace the 3rd one since it seemed to go somewhere past the drivers fenderwell. Do you think this main harness part would interchange with one from a 3.0 or 4.0? I'm pretty sure things get different after that junction block though. But from the limited info from the haynes manual, they all seem to share the same pin numbers as well as wiring colors. The reason I ask is because my truck is a 1998 2.5L and my boss has a 1998 B4000 2wd laying around in his yard and says I can take anything I want for free. Any help would be appreciated!
