Is the gauge sender close to the thermostat or at a point just after where the coolant enters the engine from the lower rad hose? Why would the thermostat stay open when the coolant around it is less than it's set closing temperature? At some point that cooled coolant, which is less than thermostat opening temp, will reach the thermostat and cause it to close. If what you are saying happens then no one's vehicle would warm up in winter at hwy speeds. I used to live in Alaska and never had a problem with any vehicle maintaining thermostat temperature. Yes, initial warm up would take longer, but once that was reached then the thermostat would maintain set temperature. I will concede that there is a point where a low enough ambient temperature will cool an engine faster than it heats, but where is the OP located, where the ambient temperature is so low that the engine loses heat faster than it is created through friction and combustion?
