Engine computer location
b23
I have a 1996 B2300 and I think I have an engine computer problem.
I went on car-part.com to source a cheap one near me, but get a HUGE list of parts!
car-part said:
1996 Mazda Pickup-B2300
Engine Computer
Elec Cont Unit (ECU), (RH Rr firewall), AT, ID F57F-CCB
Elec Cont Unit (ECU), (RH Rr firewall), AT, ID F57F-CCC
Elec Cont Unit (ECU), (RH Rr firewall), AT, ID F57F-CCD
Elec Cont Unit (ECU), (RH Rr firewall), AT, ID F57F-CDB
Elec Cont Unit (ECU), (RH Rr firewall), AT, ID F57F-CDC
Elec Cont Unit (ECU), (RH Rr firewall), AT, ID F57F-CDD
Elec Cont Unit (ECU), (RH Rr firewall), AT, ID F57F-CDE
Elec Cont Unit (ECU), (RH Rr firewall), AT, ID F57F-LB
Elec Cont Unit (ECU), (RH Rr firewall), AT, ID F57F-LBMR
Elec Cont Unit (ECU), (RH Rr firewall), AT, ID F57F-MC
Elec Cont Unit (ECU), (RH Rr firewall), AT, ID F5PF-ATA
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F57F-AB
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F57F-ABMR
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F57F-BYB
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F57F-BYC
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F57F-CBA
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F57F-CBB
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F57F-HB
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F57F-KA
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F57F-KB
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F5PF-WA
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F5PF-WB
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F67F-VA
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F67F-VB
Elec Cont Unit (ECU), (RH Rr firewall), AT, ID F5PF-ASA
Elec Cont Unit (ECU), (RH Rr firewall), AT, ID F77F-JB
Elec Cont Unit (ECU), (RH Rr firewall), AT, ID F77F-JC
Elec Cont Unit (ECU), (RH Rr firewall), AT, ID F77F-KB
Elec Cont Unit (ECU), (RH Rr firewall), AT, ID F77F-KC
Elec Cont Unit (ECU), (RH Rr firewall), AT, ID F7PF-CBA
Elec Cont Unit (ECU), (RH Rr firewall), AT, ID F7PF-CCA
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F57F-BZB & BZC
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F67F-WA & WB
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F67F-XA
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F67F-XB
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F67F-YA
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F67F-YB
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F6PF-BEA
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F6PF-BEB
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F6PF-BEC
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F6PF-BFA
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F6PF-BFB
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F6PF-BGA
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F6PF-BGB
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F6PF-BGC
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F6PF-BHA
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F6PF-BHB
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F77F-LA
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F77F-LB
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F77F-LC
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F77F-MB
Elec Cont Unit (ECU), (RH Rr firewall), MT, ID F77F-MC
:bawling: Huge... list...
So my question is where do I find my current engine computer to see which one I need to replace it with?
Right-hand rear firewall... re. firewall - engine side or inside the cab? Right-hand from inside car, or from outside (driver side/pass side is easier for me to understand).
RH/LH is always from the drivers seat.
Look at the firewall, right above the engine. See that big harness plugged into something, thats the computer.
