P1443 is a mechanical fault code meaning that wireing is not involved. Possible causes are:
Obstructed, open or cracked hoses between EVAP canister purge valve and intake manifold. Check ALL related hoses from engine to purge valve and from purge valve to tank for splits or leaks. If the hose between the purge sensor and solenoid is leaking it MUST be the same length and diameter.
Damaged EVAP canister purge valve.
Damaged PF sensor.
For
