Engine brake in 1st
PRanger
NorCal
98 3L auto trans. When I drop it in to 1 I have zero engine braking, almost as if it is in N. it accelerates and drives in 1 but once u let ur foot off the gas it drops to an idle rpm and has no compression to slow me down. Not the torque converter because you can do all of this from a dead stop and you get the same results. Any opinions and information on what I need to do to get it back to working is appreciated.
Check your transmission fluid lately?
I've never actually used an Automatic for that...I do it all the time in my 5 speed...but mostly to jump start it when it dies...
i think he means how when you get going and say..get to like 25 in first gear and left off the gas, it doesn't slowly rev down.
sounds like a blown valvebody gasket
Not really. A blow valve body gasket would cause a myraid other problems that are not present up to and possibly including total loss of transmission operation.
Sounds more like a toasty coast clutch.
Right from the shop manual.
The coast clutch is hydraulically applied when the transmission is in 2nd and 1st position.
When applied, the coast clutch locks the input shaft to the front planetary carrier, thus preventing the one-way clutch from overrunning when the vehicle is coasting.
This allows the use of engine compression to help slow the vehicle and provide engine braking.
TSB
03-22-10
  • TRANSMISSION - 4R44E - 4R55E - 5R44E - 5R55E - LOW LINE PRESSURE READING AT WIDE OPEN THROTTLE (WOT) - POSSIBLE DIAGNOSTIC TROUBLE CODES P0732, P0733, P1762 - VEHICLES BUILT BEFORE 12/1/2001
Publication Date: October 31, 2003
FORD:
1995-2001 EXPLORER
1995-2002 RANGER
1996-1997 AEROSTAR
1997-2001 MOUNTAINEER
2000-2002 EXPLORER SPORT
2001-2002 EXPLORER SPORT TRAC
This article supersedes TSB's 03-11-9, 02-13-8 and 02-08-2 to update the model coverage.
ISSUE:
Some vehicles built prior to 12/1/2001 may exhibit the following shift and engagement conditions:
  • No 2nd Gear
  • No 3rd Gear
  • No Engine Braking In Manual 1st.
Out of specification pressures controlled by the transmission main control valve body separator plate may be the cause. ACTION:
Verify the condition, the main control valve body separator plate may need to be updated to the latest level. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
CAUTION: A NEW SEPARATOR 7Z490 MUST BE USED WHEN INSTALLING THE SPECIAL SERVICE KIT 7M203 OR ADDITIONAL TRANSMISSION DAMAGE MAY OCCUR. REFER TO THE PARTS APPLICATION CHART IN THIS ARTICLE FOR CORRECT SEPARATOR PLATE PART LISTING.
NOTE: THIS ARTICLE DOES NOT APPLY TO ANY OTHER CONDITIONS OR COMPONENTS THAT MAY CAUSE SIMILAR SYMPTOMS AND IS ONLY WRITTEN TO COVER THESE SPECIFIC CONDITIONS.
NOTE: AN IN-LINE SERVICE FILTER IS NOT REQUIRED TO BE ADDED OR REPLACED FOR THIS TSB.
  1. Verify that one or more of the following conditions exist.
    • Low Line Pressure While In Drive At WOT
    • No 2nd And/Or No 3rd Gear
    • DTC P0732, P0733 Or P1762
  2. Install Kit (3L5Z-7M203-JA) to update the main control valve body assembly, refer to the installation procedures found in the kit.
  3. Reinstall the main control by continuing to follow the installation steps listed in the Workshop Manual, in-vehicle service, main control valve body.
  4. After completing the procedure, verify the condition has been corrected.
  5. Clear all DTCs.
TSB
03-22-10
FORD:
1995-2001 EXPLORER
1995-2002 RANGER
1996-1997 AEROSTAR
ISSUE:
  • No 2nd Gear
  • No 3rd Gear
SERVICE PROCEDURE
  5. Clear all DTCs.
Fine, if you are going to go running OASIS at 10 PM you can win. I'm too lazy to sort through all those TSBs this late at night.
How fast are you going when you do it? Not sure when this feature was added, but I know for sure on newer trannys if you drop it into first going to fast it just won't go, the computer stops it.
No I mentioned it does the same thing whether you start at 0 or at 25 mph. I really think it's the coast clutch. Not gonna lie when I was high centered over a tree branch my pop was revving it way to high in 1st gear and 4lo and I thought I heard what sounded like a twig snapping. Kinda like a differential snap. Diff was fine because I took the cover off no shavings or broken teeth. Can the coast clutch break and make such a noise? BTW my engine braking works perfect in 2nd this problem is only in 1
So where is this coast clutch? any idea on cost to replace?
The coast clutch is internal to the trans.
There are a few things you can do to test various aspects of the transmission's operation.
First get up to about 35 to 40 MPH and drop the trans into manual low (1st). It will shift into 2nd gear and stay there until it gets below 30 MPH. If you don't get engine braking while it's still in 2nd, that tells us something.
Next, get up to about 55 and hit the OD cancel. If you get engine braking right away, we know the coast clutch is working.
Engine braking works fine in 2nd or D w/ OD OFF it's strictly 1st :sad:
