wrecking-crew
- Sep 6, 2008
- Age
- 35
- dirty jersey
- 06 chevy
im looking to start my own little trs enduro race team.
the areas you should to live in is pa or nj.
LINKS__________________
general rules
truck rules
dirt track rules
asphalt rules
specific rules for wall speedway
racing class' page(no learning involved, just what you can use in races)
race proceedures
payouts
_______________________________________
*****any updates will be in this post only**********
racetracks located in
wall stadium/speedway(circle asphalt track)
Grandview, PA(dirt track)
if you'd like to join just say so even if its to help in the pits
requirments for trucks:
ford ranger(or any compact truck
) must be 2wd and all stock no mods(reg cabs as far as i know)
steel wheels
street tires(no cutting tires !!only allseason car tires!! and just get the cheapest)
4 point roll cage($300 or so) *(no frame reinforcment)*
they may need fuel cells
use regular pump gas
you need to stip the truck(no exterior trim, no interior, no glass other than windsheild and no lights)
probably needs manual fuel and battery cutoff switches
you need a full racing suit setup and helmet
up to date racing belts(i hope no crotch belts.......)
up to date racing seat
must keep bed sides
and the will to race and know the posibility of killing a ranger
recomendations from current racers
80's-early 90's mini trucks
long wheel base for better turning
v-6 fuel injected
cage put on so that if the truck dies, you can change the cage over to another truck(saves you $300)
did i also mention that some sponsers will pay $200-300 most likely paying for the truck and rollcage.
general rules
truck rules
dirt track rules
asphalt rules
race proceedures
payouts
steel wheels
must keep bed sides
v-6 fuel injected
