End link question on lowered truck
MrGearhead
Illinois
3.0 V6
Hey all,
I’m installing my 3” lowering springs on my ‘06 this weekend. I looking to go pick up a pair of shorter Energy Suspension sway bar links. What length links are the lowered guys running?
Thanks Matt
After doing the drop to get the needed length one simply measures the distance from the control arm mounting point up to the end of the roll bar with the roll bar in it's original *proper* horizontal position.
For the front, it wasn't critical, so I'm not sure I changed it.
For the back, more so when you flip the axle to over springs, you will bust the sensor if you don't adjust length. I move the links up with new holes in the frame. I measured 3" up and called it good.
