gzeleniak
- Jun 10, 2014
- Automatic
I have a 1987 Bronco II with a 5.0 Liter V8 from a 1993 Thunderbird installed. I did the conversion a number of years ago, and have had no problems passing smog (all factory controls are installed). This year, I cannot pass, the NOX test is way high, once before I had the same problem, it turns out the pipe from the exhaust header to the egr was broke, fixed the leak, passed with flying colors. Now I have checked all the components and they all test OK, but the EGR is not activating when I drive. The EVP, the EGR valve and the position sensor all work fine, but there is no activation when I drive. It is like the signal (the ground from the EEC) at the EVP solenoid is not being sent to the solenoid. I have checked the continuity from the EEC to the solenoid, it is fine. If I hook a ohm meter up no ground is seen, but if I manually ground the solenoid, the egr opens fine.
My question, what conditions have to be met for the egr to begin to function. Does the ECT have to show a certain temperature? I have a 180 thermostat in place, instead of the 195, but I did force the system well over 195 and road tested it, but still no egr. I verify the ECT signal matches spec. What else would keep the egr from operating? I find it hard to believe the EEC is bad, but that is my next best $300.00 guess. I did pull the codes It passes KOEO test every time, If I run the car, but not let it get near 180, the KOER test passes, If I run it and it gets over 180, the KOER test throws a 332, insufficient EGR.
Any ideas would be helpful.
Thanks
Thanks
