Electronic Engine Control - IV Pin diagram
aemiller
PA
Can someone please point me to (or post) the pin diagram for a 1990 2.9l Ranger EEC. I'm getting the check engine light with a 67 error code. My mechanic loaned me his breakout box. I'm having trouble finding the pin diagram I need to make the diagnosis. Thank you!
Hello, I have a factory PCM pinout diagram for my 1992 R10...Ranger.
Welcome to TRS :)
67 is a Neutral switch code
Do you have a manual or automatic transmission?
Manual uses a Clutch pedal switch
Automatic uses an NSS switch on the drivers side of transmission above shifter
This is a generic EEC-IV wiring guide: http://www.auto-diagnostics.info/ford_eec_iv
Pin 30 is used for "neutral" or "in gear"
"In neutral" would limit RPMs to 3,000
And problem with "neutral" switch could also cause a No Crank situation, it prevents "starting in gear" so has a few functions
The problem is solved!!! And thank you for your replies.
I discovered this morning that my 2.9l has two engine coolant temp sensors. One connects to the gage in the dash. That one was working - and was working even before I installed a new engine coolant temp sensor in it, trying to fix a problem that did not exist. :(
The second temp sensor is located down under the air throttle and difficult to see. That one goes to pin 7 on the EEC. Once I found it this morning, I could see that the connector was unplugged. When I plugged that back in the check engine light disappeared and the engine is now starting and sounding much better. :):)
FYI - it is a manual transmission. Even though it was showing a 67 neutral safety switch code, it still runs. Now that there is no check engine light, I'm inclined to think that the 67 was a false code.
OK - in trying to edit my post, I ended up with two. Is it possible to delete one?
I believe the code 67 is due to pulling the codes with the manual trans in gear.
I'm not sure about deleting a post.
Good work (y)
Yes, all fuel injection engines have 2 temp units
12volt temp sender for dash temp gauge(used on all engines since day one)
5volt ECT sensor for computer that runs the fuel injection(computer needed a more sensitive temp reading)
When Ford switched Rangers to a Digital dash in 2004 only the 5volt ECT sensor was needed/used
Yes, code 67 was not an "action" code you need to deal with in this instance
