Electronic 4 wheel drive pushbutton overhead interior console removal
IIBRONCOS
AZ
I have pulled on it, yanked on it, looked for some type of attaching hardware and cannot remove the overhead electronic console for the 4 wheel control inside my 1988 Bronco II.
I would appreciate any insight you may have.
Use a small screw driver to pry forward and down on the notches in the map light lenses. Once the lenses are out you will see two screws. Remove the screws, pull the rear of the over head console down about an inch, then push the whole thing forward to release the front clips.
I appreciate the quick response and will give it a try. Thanks
