- Nov 27, 2008
- central IL
- State - Country
- IL - USA
- Drive
- 2WD
- Automatic
- Total Lift
- 6+3
- Tire Size
- 33/12.50/15
I am having fits with my truck so I was trying to find the electrical problems. I hooked up a test light between the negative battery cable and negative post. It lit up, so I start pulling fuses inside under the dash and nothing. I pulled the fuses in the engine compartment and it went out. The fuse was 40 amp fuse panel fuse. I am not sure but have tried looking everywhere.I have about half of the engine compartment wiring harness unwrapped. I have not found any bad wires. I have taken the dash apart a bit, still need the take the gauge cluster. I am thinking it must be in the truck because when I unpluged the wiring harness the test light would not light up. I do not know much about electrical stuff. I did hook up the meter set it to volts and it was reading around 11.90 volts. I would think it should not read anything? I'm not sure. Any ideas on how or what to check.
