Ranger Mark
- Dec 19, 2017
- So. Cal
- Automatic
- My credo
- Alumni: Hard knocks F.U.
This is a little involved and maybe stupid but, here it goes.
2 scenarios:
#1, You have a relay to let's say a light bar. Across the coil, 85 is wired to ground and power is run to a switch then down to 86.
#2, same relay, same light bar. Wire from source through a fuse to 86. 85 is wired to the switch which is wired to ground.
What are the benefits of either? I see Ford uses option 2 a lot. Is this common for automotive wiring?
2 scenarios:
