OilPatch197
- Sep 23, 2007
- Age
- 96
- Automatic
1993 Buick Regal with a 3.8V6 and a auto tranny.
Okay this is the story, I just replaced the alternator with a new NAPA alternator, drove it a few miles making sure it works, it worked great. So I parked the car and removed my overflow tank and cleaned out the tank, reinstalled tank.
Then I removed the battery cables(to check for corrosion) and when I replaced them, (installed positive first then ground wire) I noticed that the engine compartment light did not light back up.
Now about a week later I came out and noticed I had NO POWER, nothing. So I checked the voltage at the battery, .6 volts.
So I preceded to do a continuity check between the Positive and Negative battery cables at the battery, thinking maybe the battery shorted out...
The Multimeter went, BEEEEEEEP!
I removed battery then rechecked the continuity of the battery....no beep. NOW I check the naked battery cables, yep I got a short!
Now I am thinking, hmm new alternator COULD be bad, so I disconnect the power connector, I still got a short in the wiring.
The Charging system is basically this, I am focusing on the positive side, as somehow it's shorting with ground somewhere.
I disconnected the engine bay light, as I have the hood up, it would be typically on.
The alternator fuseable link, positive battery cable and the fuse block fuseable link all connect at the starter solenoid.
My next step is to remove the wires from the starter solenoid junction, and check for shorts.
Any advice on best practice to find this short?
