Quill
- Sep 28, 2007
- 88 Bronco II, 8
Hey everyone, my 87 Ranger is not getting power to the fuel pump. The pump is good but no voltage to it. The inertia switch has been bypassed so it is not a problem. I checked the fuel relay up by the solenoid at it is fine. When the key turns on it clicks the relay. I tested it at the auto parts store to make sure. I took the fuel pump off and check the wires to it with the ohm meter and it beeps. Any ideas? Thanks so much for your consideration.
