Electrical Issues, Fuel pump staying on with key
97fordrunner
New Richmond, WI
Hey all.
So the new issue is the fuel pump is stays on when I turn the key on engine is off. I know it should only be on for a few seconds to prime, My question is what tells the computer to shut off them pump when it is primed? and is this the probably issue? Also when the pump runs for say 20 sec or so the relay starts freaking out shutting on and off then returns on. The Relay is new hardly any time on it at all. When the truck is running it is running rough and from what I can tell seems to flood itself. Is this a possible fuel injector stuck open and how could I test that? THanks
