Electrical Issue
Spencer Elder
Idaho Falls, ID
Why would Electrial shut off/start to die on my 88 ford ranger when i give it gas to accelerate my radio dies and the lights dim as if im pulling a huge power load but only when i accelerate i have cheked the battery replaced the + and- power cables and alternator and it seems like it all started after i pulled this girl out of a snow drift and had a strong rubber smell now all this wasn't sure if that caused anything
thnks spencer
sounds like you have some burned wires somewhere. i would check the power wire at the back of the alternator.
well i just replaced it after this started happining i judt dono im stumpped on all aspects in thinking about just taking to this shop where they will do basic diag. for 40 to 50 bucks but it would be nice to figure it out by my self i even checked the starter wires just to see if that could be it but i might recheck them agian just to make sure
thnks spencer
HMMM
how about the belts?? what kind of condition are they in??
IS this auto tranny?? Maybe check the cooler lines up by the radiator... gotta pin hole spraying the belts after the snow pile???
just thoughts...hope it helps
so i took it to this shop and both my motor mounts bolts are snaped and an electrical fire started by the gas pedel and they found out my front axel is shot im instructed to keep the hubs unlocked and it out of 4 so i want to know what you guys think it will take and how much i would be they don't know exactaly what is wrong but i think it's might be the spider gears
WOW~ that must of been a pretty good shot into the snow.
Depends on how much you're willing to spend & what you can do yourself...things like that.
Probably best to get whole donor truck or replacement component's from the salvage yard...there most likely going to be other suspension and drive line parts compromised too. just things to concider.
