BigSteve
- May 8, 2013
So I have been doing everything possible to track down what I believe to be is a ground issue. Ever since I got the truck it has had a little flicker to the lights. Anytime the lights are on and I turn on anything else electrical or even just hit the brakes, they flicker. Just a quick millisecond flicker but its there. And it idle I do notice a drop in brightness on everything.
Now, what I have done is the 3G alternator upgrade, checked, cleaned and replaced every ground I can find on the truck and it has gotten better but still there.
TONIGHT: I noticed when I pulled up to my garage door, and the lights dimmed just a bit as I rolled to a stop, I wiggled the steering wheel up and down and TADA, if I held it in a certain spot they would stay bright. Let it go and they dim again.
My first thought is ignition switch. I tried the ol wiggling the key and that did nothing. Wiggled the headlight switch and that did nothing. But doing it to the steering wheel and I could watch the lights dim and brighten.
Thoughts or ideas would be greatly appreciated as I am almost at wits end with this problem.
