The83RangerMan
- Feb 9, 2011
OK so today i went to jump start a car and i noticed my batt was warm prob 70 deg or so and the acid was gurgling and hissing out the vents. So i put a tester to it. At the batt i got a reading of 13.7 volts with ignition off 14.7 volts at idol, and 15.1 volts at around half throttle. So ok voltage regulator went bad, now the regulator was only 6-8 months old but stuff happens. so I replace regulator. No change volt readings were the same. well batt was just barely enough for the truck anyway came out of my four banger b2000. So I upgraded to a new 800 cca batt. (note old bat tested good in the batt tester at parts store.) While replacing batt i realized ground to block was corroded so i took apart cleaned with wire brush and put back together. Go back to parts store to drop off old dead core batt, and have them test again, now at half throttle its up over 16 volts at the batt
, so they warranty the regulator again just for the he11 of it and give me another, and its still up at 16 volts. all fuses are good, no surges, no hot wire bundles to indicate a short, However my temp gauge is all over the place only elec issue i can find and i think the sender unit went bad. Any ideas I'm all sorts of confused and just about out of ides almost time to tear dash apart but i swear there aint no shorts. Or could this be normal even with being way out of the safe parameters.
