electric fan
black06xlt
i have a 2006 with the 4.0l im wanting to the clutch fan and replace it with an electric fan. i got an electric fan from a 2002 ranger with the twin cam 2.3l would that fan work on my 4.0l?
Let !e know if it does and how you did it. I have e one from a 01. And I have an 04 I'd like to put it in
Sent from my QMV7B using Tapatalk
will do marty... i ordered a fan controller and a radiator hose adapter just waiting on parts to come in
i have heard bad things about the controllers with the probe. i found on amazon a derale fan tempeture switch that requires a hose adapter also on amazon that uses a sending unit to tell the fan when to come and when to shut off
Cool just wondering. Do they come with wiring and relays to install?
the kit does come with wiring relays fuse and all needed hardware for the install
I went with the Flex-A-Lite kit. Comes with a direct-fit fan, controller, and 10A fuse. You have to provide your own relay unless you want it to run with the engine off.
