I am running a 16 inch electric fan from the local autoparts store. I paid $75.00 for it years ago, I see they want about $81 for it now. You can probably get it cheaper online somewhere. If you look on the box they say this 16 inch fan is good for a big block engine, don't believe it. But it does cool the little v6 well, and the load on the alternator and battery is not too bad.
I used their mechanical switch also. See the picture below. I actually had this setup on my ranger and ran it for about 6 years on it, and have been running the same setup on my bronco II for 3 years now, I just swapped the whole thing over. With the thermostat, the instructions tell you to pull the upper radiator hose off, stick the probe in the radiator, and then slip the radiator hose back on and clamp it around the probe wire. This doesn't work very well at all, it constantly leaks.
What I did is shown the picture below. I tapped into one of the heater core hoses, got some fittings from lowe's, and made up the probe in the heater hose. Works great and doesn't leak.
Electric fan probe by
D Franklin, on Flickr
