2.5L ('98-'01) EGR tube removal
ben_2_go
Third rock from sun
2.5 (4 Cylinder)
235-75-R15
None at all.
What size is the EGR tube nut on the exhaust manifold end? I have nothing that I can get in there to remove it. It's big. I want to try and find a crow foot wrench to fit it. Otherwise, I'll be trying to use my rotary tool to cut it off.
I was sent this video but my manifold and EGR tube are different and it can't be reached with a wrench. Maybe this will help someone else.
i took the hood off first. 11/6 wrench plenty of penetrant overnight. mine came off with muscle and a cheater pipe. same down low. pain but can be done.😀
On my 2001 2.5L First spray it with a good penetrating oil let it soak in for a few minutes and spray it again, I use a 1-1/16" open end wrench(fits both fittings on pipe), which needs to be flipped often, Be careful not to crack or break double male fitting from EGR line into Manifold. I learned the hard way and needed to remove manifold and hacksaw out broken piece.
Appreciate your help on this
