2.5L ('98-'01) egr pressure feedback sensor wiring
lynnted
lantana, florida
need to replace the electrical connector for the egr pressure feedback sensor on a 2000 ranger 2.5 engine. old connector fell apart and the three wires are no longer in sequence. new connector has three white wires with no instructions. need to know which original color coded wire goes to which terminal on the new connector. thanx
@RonD is the wire expert but I know I have a pic of the one I just worked on. Lemme find it, or Ron will chime in to help.
I have the wire colors but not in any order
1999, 2.5L used brown/white, brown/green and grey/red
Brown/white is the 5volts
Brown/green is the signal
Grey/red is the "ground"
I did see test article that said
top is signal
center is ground
bottom is 5v
so
brown/green
grey/red
brown/white
Its called the DPFE sensor if you want to see if you can find pictures of it with wires attached
Not sure if this is the correct version DPFE Sensor, showing HarnessConnector & WireColors?
