2.5L ('98-'01) EGR PRESSURE FEEDBACK SENSOR CONNECTOR WIRING
lynnted
lantana, florida
Working on a 2000 ranger egr pressure feedback sensor electrical connector with damaged connector end such that I don't know which wires go to which pins in the sensor. The sensor connector pins are laid out in a vertical fashion. The original three wires are : brn/grn , gry/red, and brn/WHT. Would like to know which color wire goes to which pin, for example, : this color wire goes to top pin , that color wire goes to middle pin, and other color wire goes to bottom pin. Thanks for your help
The two examples I have here are both the same. While looking at the connector with the locking clip up top and the open end facing you. The center pin is the red stripe. The left is the white stripe and the right is the green stripe
