Oh, I know. I won't tell selfish, uninformed jokes who want to do it just because they don't understand how the systems work.
EGR doesn't hurt performance, EVAP doesn't hurt performance, cats wont hurt unless you have done some serious work the the heads and intake, you don't have a belt driven AIR pump, which is about the only emissions device that will hurt performance/economy on a fuel injected engine.
Oh, also, your fuel injection and distributorless ignition would fall under the umbrella of "smog crap" that you want to get rid of, so by the time you install a distributor and carb all the more you should have to do to avoid the CEL is throw the light bulb in the trash.
Now, since you don't seem to understand how things work (I can tell, because if you did know you wouldn't have to ask the question), don't mess with the emissions control system.
I'm cool about most things. The emissions controls are there for a reason, the system is designed to work with them in place, and they are effective and do far more good than harm. As a tech and someone with respiratory issues people like you who just want them gone because they cling to the outdated, ignorant, and no longer correct prejudices of the previous generation hits a real hot button with me.
Is that book learning, or have you actually run the same vehicle with and without an EGR and noted the difference in power and fuel mileage?Lol thats funny cause EGR increases fuel economy....
P.S. Yes, I have.
If the composite upper has egr stuff, and your engine has egr stuff, you might as well hook it up.
If your engine has egr, but the composite upper doesn't then the egr stuff can be removed from the engine and deleted from the PCM with a handheld tuner like an SCT xcal.
