EFI 460 in a 94 Ranger
Oakes
I have a 1994 Ranger it was originally equipped with a 2.3 liter, I have a complete 91 F350 with a 460. I want to swamp the 460 int the ranger. How an what do I need to do this?
no inner fenderwells?
beefy front springs?
fully boxed framerails?
majorly strong differential?
The frame is a 1978 bronco rail so that don't bother me. I am needing to know what I need for wiring? If I get a 5.0 wiring harness will it plug in with the editor 460? I have read that it would.
Whatever is on the f350 to make the engine run, well need to be put in your ranger to make it run.
Sent from my A500 using Tapatalk 2
91 would be a EFI (electronic fuel injection) vehicle , so you'll need the engine , engine wiring harness , and computer ,and possably the incab harness from the f350 , you might beable to modify a 5.0 harness to work , tho it'd be easiest to just use the 7.5 harness , keep in mind the 460 is not gonna just drop right in without some work , and your most likely going to keep a body lift to clear the much bigger engine , bigger transmission , ect , plus depending on if the donor is 2wd or 4wd you may need a duel sump oil pan to clear the k member...
